Mil1ion, that was/is after I lowered the truck from the jackstands.
Instig8r63, I did tighten all the bolts before I lowered the truck. Should I raise the truck, loosen the I-beam bolts, lower the truck, and then tighten them?
I always tighten the bolts loaded because a front end guy (for 20 years) that I know from a Ford dealer told me it was the correct way. I guess it initially puts unde strain on the bushings.
