cpu code location
Old Jul 25, 2006 | 02:25 PM
ponch37300's Avatar
ponch37300
cpu code location
I've been searching for over half an hour now with no luck. I know it has been posted before but can anyone tell me where the pcm code is losated on the pcm. I have a 03 7.3 and remember reading about using a mirror, tried that and couldn't see anything on the back. Guess i will just have to undo it and see if i can find it. Anybody point me in the right direction before i start tearing things apart that don't need to be. Thanks in advance
Old Jul 25, 2006 | 02:33 PM
Kwikkordead's Avatar
Kwikkordead
On my '99 you have to remove the cover on the inside and there is a blank covering the pins that you would plug a chip into. The cpu code would be on that blank.
Uzumati's Avatar
Uzumati
http://www.dp-tuner.com/DP-TUNER%20PCM%20CODE.pdf
Old Jul 25, 2006 | 02:42 PM
RAMPAGE_F350's Avatar
RAMPAGE_F350
Ponch, if you are doing this to get your ducks in a row for a DP-Tuner, Jody can look up your CPU code. All he needs is your VIN#. That is how I ordered mine because I couldn't read mine with a mirror either. Hope this helps.
