Power steering fluid
Old Jul 25, 2006 | 01:36 PM
lvseicsh's Avatar
lvseicsh
I've been putting STP power steering fluid in my resivoir.....I just read where you are supposed to use ATF......Am I hurting the system?
I've been using a "turkey baster" to suck all the fluid out and fill it up and run for a while and repeat....the fluid that comes out is "root beer" color, but the fluid going in is clear. I think I should do a flush, but couldn't find the procedure using the search function. I saw one on the OTHER forum and I really trust you guys more. I want to get rid of that grind whine when I brake or turn. Won't the flush help this?
Thanks,
Leo in Mississippi
Old Jul 25, 2006 | 01:55 PM
670johndeere's Avatar
670johndeere
Been there Done that, I couldn't find the thread I did mine with but basicly it said to remove the return line off of the hydrobooster( this is the line that returns to the PS reserviour) and install a 3/8 line on and run it into a bucket or container. Have someone start the truck and turn the steering wheel from stop to stop, while someone keeps filling the reserviour with new ATF. Some guy's on here are going with the Synthetic ATF. You shouldn't have hurt anything, I did the same thing. Just flush it good.
Old Jul 25, 2006 | 02:49 PM
Fat Diesel's Avatar
Fat Diesel
John Deere has it right. I've done mine twice now. The only thing I would add is have the person also gently press the brakes a few times to get that fluid circulating out as well.
Old Jul 25, 2006 | 07:43 PM
lvseicsh's Avatar
lvseicsh
Thanks for the info,
how important is the fluid cooler? I bypassed the auxillary ATF cooler when I installed my Tru-cool max.....could I use it in series with the p/s cooler for better cooling?
Old Jul 25, 2006 | 07:45 PM
lvseicsh's Avatar
lvseicsh
Does anyone know how many quarts that system holds?
Old Jul 26, 2006 | 10:09 AM
cphill58's Avatar
cphill58
hold on ...I'll go disconnect my return hose and pump it into a bucket and let ya know. First time I put in PS fluid too ...just to top it off . Never did flush it out , Ya think I should ???
Old Jul 26, 2006 | 01:06 PM
Fat Diesel's Avatar
Fat Diesel
Get three quarts of Syn ATF and flush it all out. You'll know when you're done because the root beer coming out the hose will turn color into more like a grenadine.
Once you are done, park the truck overnight with the wheel turned all/most of the way to one side. The next night turn it the other way and leave it. Repeat for a few nights to get all the air out of the system.
Old Jul 26, 2006 | 01:23 PM
empiretc's Avatar
empiretc
If you want a quick fix to get rid of the noise, add some stp. I never had to time to a flush, so i took some fluid out and added a bottle of stp. It has been silent ever since.
Old Jul 26, 2006 | 03:49 PM
lvseicsh's Avatar
lvseicsh
Thanks,
I'll do it ASAP.....you guys ROCK!!!!
Thanks again,
Old Jul 31, 2006 | 02:45 PM
lvseicsh's Avatar
lvseicsh
I put 3 quarts of synthetic ATF through the system and did the "turn the tires overnight" trick a few times and I STILL have the whine and grind......But I did notice that the braking is much better......That grinding and whining is SOOOO ANOYING!!!!!
Any other ideas?
THanks,
Leo in Mississippi
Old Jul 31, 2006 | 10:19 PM
HUNTER10's Avatar
HUNTER10
I did the same thing, and mine still whines as well. I think I'll try the STP trick next, any other ideas - please tell
Old Jul 31, 2006 | 11:02 PM
empiretc's Avatar
empiretc
yeah, the oil treatment "honey" looking stuff in the blue bottle. mine hasnt whined at all since.
Old Aug 1, 2006 | 11:42 AM
lvseicsh's Avatar
lvseicsh
I'll try it today and let you know.
Thanks,
Old Aug 20, 2006 | 11:07 AM
Wieckster's Avatar
Wieckster
how much STP in the blue bottle should I add to the system?
Old Aug 20, 2006 | 02:25 PM
SpringerPop's Avatar
SpringerPop
So, lvseicsh,
Did the STP cure your noise problem?
Pop
