Cleaning Ebp
Old Jul 25, 2006 | 12:03 PM
eric777's Avatar
eric777
Smile Cleaning Ebp
i put a post about an ebp code and some said i could unplugg it and some said that it could be cleaned out - if i clean it how do i do that ? can i just blow it out with some compressed air
but maybe i should unplugg it?? your thoughts
Old Jul 27, 2006 | 11:54 AM
marvinlong's Avatar
marvinlong
I took the tube off and sprayed carb. cleaner through it. It was pretty clogged. Was going to get a piece of wire cable and hook it to a battery op. drill but didnt have to. The sensor can be had on e-bay for 20-35 dollars. Taking the tube off was a pita. i think it was 16mm a the manifold,don't remember what size coming off sensor. Good Luck!
