Cat Delete Pipe
Old Jul 25, 2006 | 07:25 AM
chata's Avatar
chata
Cat Delete Pipe
anyone know where I can get a cat. delete pipe that will fit my banks 4" system. I would like the pipe to slip on and off as the cat. did into the existing syste,. No welding.
Old Jul 25, 2006 | 01:44 PM
jimbo beam's Avatar
jimbo beam
im not sure of an existing pipe, but you could get a straight section of 4 inch pipe take some mesurments and have a shop bend it up for ya, have the ends flared so it slips over the old pipe and clamps into place
Old Jul 26, 2006 | 10:53 PM
fordf150guy's Avatar
fordf150guy
you could also have flanges welded on the cat section and your straight pipe section. that way when you need to change them out its just a matter of un-doing a few bolts. sometimes if you use clamps it deforms the pipe making it a PITA to get apart and back together. any local exhaust shop should be able to set you up.
