Sponsored by: Kumho
ABS Gap
Old Jul 24, 2006 | 05:54 PM
RangerWilly's Avatar
RangerWilly
ABS Gap
Anybody know the ABS air gap between the tone wheel and the tip of sensor. This would be for 2001 Ranger 4WD/OffRoad Exct. Cab 4.0SOHC front left and right ABS sensors???
Old Jul 25, 2006 | 05:36 AM
SRD4X4's Avatar
SRD4X4
Isn't the hub/bearing a sealed unit on your truck? Or is the tone ring located on the axle?I don't know what the gap is supposed to be,but if you have a sealed hub then there's no way to set/change the gap (other than to increase it,which usually never happens).Did you pull any codes?
Old Jul 25, 2006 | 05:52 PM
RangerWilly
1)Yes,the hub/bearing is a sealed unit.The tone ring is in the unit.Yes it is on the axle b/t the bearings.
2)Yes there is a way to set the gap.
3)Re-read my thread. It did happen.
4)I can "pull" codes (i.e. "check engine light") but not ABS codes.Note: The ABS light is on.
