FE exhaust exchange
Old Nov 14, 2002 | 07:11 PM
rayray2k22002's Avatar
rayray2k22002
FE exhaust exchange
Old Nov 20, 2002 | 08:16 AM
R100RT's Avatar
R100RT
FE exhaust exchange
Can any one tell me if my drivers side exhaust manifold can be replaced with one from other FE engines or cars?
ty
Eric
Old Nov 20, 2002 | 09:08 AM
banjopicker66's Avatar
banjopicker66
FE exhaust exchange
Any truck FE manifold will work; many of the car manifolds varied for specialty applications.
Most of the variations revolved around higher performance engines, which translated into different bolt holes, or around the need for special shapes because of less room in the engine compartment.
The trucks have so much room in there that the larger "log" style exhaust manifolds could be used with no problem.
If you get one from a truck, it should be the same, whether 352, 360 or 390.
Chack it for warping and have it milled if necessary. They are prone to warping, and milling will save you a LOT of time and aggravation later.
Check out the cool FE forum here too.
Old Nov 20, 2002 | 09:36 AM
Brian's Avatar
Brian
FE exhaust exchange
Some of the car manifolds have a smaller exit flange pattern. I found this out the hard way. Had the manifolds all bolted up then tried to install the exhaust pipe. No Go!
If you need a pair of manifolds I can sell you some cheap.
Old Nov 20, 2002 | 08:37 PM
R100RT's Avatar
R100RT
FE exhaust exchange
I just need the left side but if the price is right, I buy both.
