hard upshift 1,2 only
Old Jul 24, 2006 | 07:30 AM
baxxtracker01's Avatar
baxxtracker01
Question hard upshift 1,2 only
i have a 97 f150 , 4.2L,recently i took my motor out to fix a bent rod,thats another story, anyway i got it all back together and now i have this hard 1,2 upshift ,then smooth after that. i had it on a jack for a couple of weeks when i had the motor out , i checked the u joints ,the one on the trans end has a little play by grabbing the yoke the other is tight . anyone with any ideas please holler at me .
Old Jul 24, 2006 | 11:01 AM
l-m tech's Avatar
l-m tech
you moer than likely have a broke 1-2 shift accumulator spring.drop the pan and on the drivers side front next to the valve body there is a half dollar sized hole,push up on the cover and remove the snap ring .the lower spring is probably busted.replace with a new spring andn replace the accumulator to .there is also a spring on top of the piston
