Rad. Overlow Blowing Hose
Old Jul 23, 2006 | 11:23 PM
D HOOKER's Avatar
D HOOKER
My 6.0 had the hose underneath the overflow tank blow off. It appears that the clamp failed and the hose came off. Went to parts store and all they had was a clamp that was a little too big, but thought it should work. Seemed to get it tight enough but it blew off again a couple of days later. Have now replaced with a Real Tight clamp.
My question is, why would the overlow tank seem to be under pressure? Is this normal? The hose appears to be routed towards the water pump, this suprised me a bit.
Old Jul 25, 2006 | 08:05 PM
BowTieHatr's Avatar
BowTieHatr
it will be under pressure, as to why it keeps blowing the hose off could be several possibilities
Old Jul 26, 2006 | 03:29 PM
rrrrick's Avatar
rrrrick
my 6.0 hose blew off because the factory clamp was never fastened during production
Old Jul 26, 2006 | 04:18 PM
biz4two's Avatar
biz4two
Arrow
Yes it is normal. This is a closed or pressurized system. The FORD hose clamps have been suspect for years on all SD's...even us gazzers. It was just time for your's to fail. I'm sure now that you have a good tight fitting clamp...you should be fine.
biz
_______________________________
2003 F250 SD SC 142" XLT FX4 V10 Auto 4x4 3.73s
Old Jul 27, 2006 | 08:59 PM
D HOOKER's Avatar
D HOOKER
Thanks for your feedback Guy's, I haven't had any problems since I got the clamp on properly.
This issue has brought up another question. Do you guys believe these antifeeze's that claim they are appropriate for "ALL VEHICLES'', I'm skeptical but thats all that was available when I had to have it.
