Okay I know I put my turbo back on last time but, now I can't get the two bolts loose that hold it to the pedistal. Anybody have any ideas? I know they're hard to get to especially the back one. I figured all the minds on here have came up with a better way to get'em off.
Reason: typo
um, they came off easy for me. did you lock tite them in place? i believe the stock bolts are 13mm, not 1/2". i could get a socket in there, and with some knuckle banging and cursing i got them to come free. they are only torqued to 18 lb-ft upon reinstallation, so dont he-man them!
take your time dont hurt anything- such as your body. watch the little plastic clip that hangs down below the hood seal, it can catch your arm if you suddenly break it loose and lose control of the socket. (ask me how i know ). i found out a deep-well 13mm socket and a 3/8" ratchet with a 8" or so long handle worked fine. it would rub the top of the exhaust housing but i eventually got it.
