Dead Tach?
Old Jul 23, 2006 | 02:30 PM
desperado_18_2000's Avatar
desperado_18_2000
Dead Tach?
My 83 F-150s tach has quit working. I've replaced the coil, duraspark II box and a few other odds & ends hoping that it would start working again but still its not working.
I've bought another tach module to replace the one thats in the dash now, as a last resort to see if i can get the tach working again. Is there anything else i can check/do to see before i swap tachs?
Old Jul 23, 2006 | 02:57 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Check the wire connections of the Dark Green/yellow wire, on the left fender skirt.
There should be two connectors for this wire located there on the fender skirt. One end comes from the coil, to the first connector, from this connector, two wires will be splitting from it, one to the duraspark, the other goes toward the second connector and your tach.
Check to see if these connections are not compromised.
Old Jul 23, 2006 | 04:17 PM
smallblock351w's Avatar
smallblock351w
my factory tach died and i ended up having to replace the tach itself. called the junk yard got a used instrument cluster and switched it out, been great since, cost me 70 dollars.
Old Jul 23, 2006 | 04:36 PM
81-F-150-Explorer
You can get that same clusters in wrecking yards here for $35.
I would have thought $70 a little pricey.
Old Jul 23, 2006 | 06:47 PM
smallblock351w
well i was just glad to have it working again, nice if you can get it for that price though.
