how to pull codes ??
Old Jul 23, 2006 | 08:10 AM
Shovelhead 93's Avatar
Shovelhead 93
Question how to pull codes ??
Thanx for all the info on oilpan and running rough but how do I pull the codes on my 87??
Old Jul 23, 2006 | 08:21 AM
jroehl's Avatar
jroehl
Go to fordfuelinjection.com and poke around a bit. Lots of good info there.
Jason
Old Jul 23, 2006 | 09:44 AM
natewill's Avatar
natewill
<a href="http://fordfuelinjection.com/?p=13">DIY Pull Codes</a>
Old Jul 23, 2006 | 10:06 AM
lv2race's Avatar
lv2race
Actron CP9015 is what I use, cost me $29.95, and is good for your application. I read you can use a paper clip as well, and codes will flash your check engine light on the dash. I don't know which female connectors in the harness to jump, maybe someone will help you there.
Example: code 123 would flash your CEL as follows; flash, pause, flash flash, pause, flash flash flash. Very easy and you will save alot of money fixing sensor and relay problems yourself.
fordguy2236
38
Oct 14, 2023 01:04 AM
scottddove
84
Sep 7, 2014 10:34 PM
renchr56
Aug 10, 2014 04:47 PM
jhobbs26
Apr 23, 2014 04:52 AM
eric777
Sep 18, 2006 06:55 PM
