5.4 misfire and codes
Old Jul 22, 2006 | 08:19 PM
sturman3's Avatar
sturman3
5.4 misfire n codes, engine runs fine at idle seems smooth , at about 1500-2000 rpm noticeable miss and lack of power. new O2 sensors , plugs, air and fuel filters, replaced coil and injector on #6 and coil on #8. getting codes 300 306 308 after chging coils and inj #6 dropped off code still getting 300 and 308, any ideas????
Old Jul 25, 2006 | 04:18 PM
biz4two's Avatar
biz4two
Arrow
When you changed plugs, did you also change out the boots? (almost a MUST do...IMHO)
Try removing a COP that is not giving you a code (ie: #1)...and replace it with #8 cylinder that is giving you a code. See if the code follows the COP...if yes, then it is still the COP. If not...then check and re-install or replace the spark plug with a new boot. Check condition of the spark plug. What does it look like?
Hope this helps some...
biz
_______________________________
2003 F250 SD SC 142" XLT FX4 V10 Auto 4x4 3.73s
Old Jul 28, 2006 | 06:53 PM
Blue Bowtie's Avatar
Blue Bowtie
8th Gear
Is fuel pressure at least 31/40 PSI?
danyboy
13
Apr 1, 2020 02:29 PM
DeBoerJM
Aug 18, 2015 07:48 PM
sherry0331
Feb 11, 2014 07:24 PM
FFEMT32
Modular V10 (6.8l)
May 10, 2013 07:31 AM
twelker_04
1997 - 2003 F150
Dec 15, 2009 08:26 PM
