I have been reading alot on turbo setups and the van turbo in particular. Will a turbo out of a 2000 e350 work for this mod. If so, it has minimal end play, is this easy to rebuild to get ride of the end play. Thanks for your help.
Yup, that turbo will work. Although I've never rebuilt one myself, I've been told it's pretty easy to do. And rebuild kits are available on eBay for right around $100. I know Kris has had is turbo apart, so he may be able to give you some tips on rebuilding it.
if you have an early 99 you need an upgrade kit to put your turbo department at par with a late 99. im not sure where it is at, but i thought it was Dieselsite. can't find it there.
yes i have rebuilt my turbocharger when i did all the mods to it. sideplay was at the line of needing rebuilt so i did it anyway. i have a gallery and i guess i should make a writeup on it, it would he helpful to some. i have all the pics i need, i think.. check out my Webshots gallery..
