Dash Pads??
Old Dec 5, 2002 | 10:05 PM
RickyD's Avatar
RickyD
Dash Pads??
Anybody have a suggestion for a dash pad replacement that doesn't cost major $$$$$. My 66s has been baked and cracked beyond repair. Maybe even something (gasp) non-stock? Does someone know if it is feasible to remove the pad and leave it off, revealing an older looking metal dash? A first class replacement would be best but it is just my trash hauler for the most part.
Old Dec 8, 2002 | 04:14 PM
zukezake's Avatar
zukezake
Dash Pads??
In the case of my 1966, I removed the pad to reviel the metalic dash, and actually got a chance to see the non-oxidized carabian turquoise. There were ofcorse holes drilled for the chrome bits.
Removal was not difficult, excepting for the two side screw in pieces left and right of the dash, one screw was rusted, and had to be dremmeled out, and I damaged the holder in the process. prying the chrome off I managed to scratch the paint a touch, but I was none too concerned personaly as I was going to remove the paint.
In my case, it being the custom cab, under the dash pad was the carabian turquoise, the exposed part of the dash was the wimbledon(sp) white.
There was ofcorse a problem with the factory glue that held the dashpad on, but i imagine there are solutions to remove it. in my case i'm stripping the paint.
There was some heavy rusting right around the window seal... i'm presently in the process today of scraping it away, but i've seen this truck without the dashpad, and it does indeed look most handsome, esp since you can strip and repaint it with ease, it's harder to construct a dash pad.
Old Dec 8, 2002 | 04:27 PM
trouble's Avatar
trouble
Dash Pads??
