Rpm
Sit in your Truck...
Press and hold thr trip Odometer reset...
Start your Engine....
Release your Trip odometer reset...
What you have know done is bring up a diagnostic mode on the display. If you cycle through the displays by pressing the trip odometer button you will ventually reach the tachometer... (If you pass it just keep pressing the button and it will cycle through all of the choices again)
My STX is around 1850 RPM Cruising at 70MPH...but I am using an Edge Tuner so I do not know if that is efffecting it in any way...
AS for 60...Never really looked for it...but regardless you know have a way to check your rpm's yourself....Good Luck
