Cab Mounting Question
Old Jul 20, 2006 | 07:06 PM
loholland's Avatar
loholland
I wonder if anyone might help me on mounting my 46 cab? I know this question has probably come up before. When the Ford factory mounted the cabs, did they use springs under the frame where the bolts passed through? If so, then did they only use them under the mounts that pass through the frame rails?
Old Jul 23, 2006 | 08:26 AM
loholland's Avatar
loholland
Well, I guess it was a dumb question
Old Jul 23, 2006 | 08:34 AM
Fix's Avatar
Fix
what size truck?
On my half ton. there were no springs. The cab was mounted over blocks of wood, and bolted directly to the frame brackets. My 41 half ton is the same.
Were there springs on yours?
Does anyone know if there is a source for rubber mounts to replace the hardwood? It seems like somone would make them. The wood mounts on my 41 make for a rough ride.
Old Jul 23, 2006 | 06:14 PM
loholland's Avatar
loholland
Thanks Fix for responding, When I bought my truck it was unassembed. I purchased a rolling chassis a few months ago and the person I bought it from had torched off the cab bolts, but under the frame rail there were springs hanging from the old bolts between the nuts and under the rail. I wondered if they were suspose to be there. I bought new wood blocks and would like to mount my cab soon. I was hoping someone had a truck that the cab has never been removed that could tell me if the springs are are there.
Old Jul 24, 2006 | 10:39 PM
3Mike6's Avatar
3Mike6
I'll look under my '42 tomorrow, but I've no idea if the cab has ever been off.
Old Jul 25, 2006 | 10:43 AM
46yblock's Avatar
46yblock
Loholland, it has been too long ago. Cant remember whether there were springs or not.
Mike
Old Jul 25, 2006 | 06:04 PM
3Mike6's Avatar
3Mike6
I just went out to look at my '42, and damned if there isn't enough light to look through under there and see. I'd have stuck my hand around, but I was afraid of grabbing a black widow.
I'll hunt up a flashlight or drop cord and take a look a bit later.
I could see the wooden blocks though
Old Jul 25, 2006 | 08:24 PM
46fordtruck's Avatar
46fordtruck
On my '46 1/2 ton, never removed from the frame, there are springs on the furthest forward mounts of the front mount (the long block at the front of cab), on the rear cab mounts, there are springs between the frame rail and the nuts. In fact the rear bolts use 2 springs per bolt...arranged as frame rail, spring, washer, spring, washer, nut.
Old Jul 26, 2006 | 08:05 AM
Fix's Avatar
Fix
Really. Springs?
Do they work?
I'm sure that someone removed the ones that would have been on my 41. Would it be worth changing the bolts and putting some springs in, or are they pretty much useless.
It doesn't seem like they could work.
I think I might still be looking for rubber mounts.
Old Jul 26, 2006 | 11:42 PM
va47's Avatar
va47
my 46 has springs in the front 2 and oak blocks under the rest . on my 47 i put rubber blocks under all of them , makes a big change in the ride.
Old Sep 7, 2006 | 10:53 PM
bob s jr's Avatar
bob s jr
grainger industrial supply carries a wide variaty of rubber mounts i think it www.grainger.com you do need a business licence or a freind with one i found a set that worked when i restored a 1956 lincoln welding machine that lincoln doent carry parts for
Chevmn56
May 6, 2014 06:32 PM
driveability
May 6, 2007 09:51 PM
F100man
62
Apr 16, 2006 07:02 PM
davidstinson
Oct 3, 2003 12:10 AM
