Manual to auto help please
Hello i have been searching all morning for posts on this subject.
I swaped out a manual trans in my 79 f250 crew cab 4x4 and replaced with a auto trans from a identical truck my problem is i need my backup lights and how do i hook them up. My current configuration is two wire and the auto trans has 4 wires.I also replaced the steering column from the same truck.
Can you please help me
Thanks
Thanks
79 trucks had the NSS on the trans. The 4 wire configuration is for NSS, as well as the back-up lights. Simply use a meter to verify which set of contacts closes when you place the truck in rev. Then take one lead with 12VDC, to one side of the contact, and one wire to the back-up lights, and you will be in like Flynn.
Good luck.
Good luck.
