Help, my windows are squeaking!
Old Jul 20, 2006 | 02:31 AM
00buck's Avatar
00buck
After detailing my truck (including windexing the windows and armour-alling the weather stripping) my rear windows are squeaking really bad when operated up & down. I didn't windex the fronts because they are tinted with after factory tint.
What can I do to the windows to make them operate quietly again?
Old Jul 20, 2006 | 03:54 AM
toddyw's Avatar
toddyw
Get some silicone spray and lubricate the channel rails and guides. that should take care of the squeaking problem and speed up the raising and lowering as well.
Old Jul 20, 2006 | 05:34 PM
00buck's Avatar
00buck
Silicone spray, got it, thanks!
Old Jul 20, 2006 | 06:02 PM
George Frasier's Avatar
George Frasier
Another option is to use "Silglide" on the window channels. It is a silicon jelly that comes in a tube like tooth paste. Put a bit on the end of your finger and rub/smear it on/into the window channel. Also works on the door weather stripping, etc.
Old Aug 9, 2006 | 01:08 AM
00buck's Avatar
00buck
The silicone made it louder, I dug up some dry graphite lube and that nocked 90% of it down.
Silglide may be what I need.
