Usually a P1400 is caused by a bad DPFE. What brand did you use? The code is set if the PCM sees less that .2V from the DPFE. If the DPFE is definately good then you probably have a wiring problem.
A clean connection is critical on any electronics. It's easy to clean it and retest.
If you remove a battery terminal for 10 minutes you'll shut off the check engine light. Then you can drive it and see if it comes back or not.
