Aerostar Ford Aerostar
General Alternator question.
Old Jul 19, 2006 | 06:30 PM
DOUG5G's Avatar
DOUG5G
My neighbors Ford reads 14V while at idle. If we rev the engine up to around 2000 RPM the voltage drops to 12.5 and the battery light comes on. The belt is tight and the alternator is about 4 months old. Does this sound like a belt issue or can the alternator be bad? It has an the spring automatic tensioner so how can I prove what is wrong?
Now the bad news....This alternator is on a 1997 Expedition. I posted in that forum but that one is not as good as this one in getting good answers.
Thanks for the help
Doug
Old Jul 19, 2006 | 08:05 PM
99f350sd's Avatar
99f350sd
Usually that happens when the brushes are wore or the armature is egg shaped. My bet on a 97 is that it needs replacing..
Dick
Old Jul 19, 2006 | 10:16 PM
bear2x2's Avatar
bear2x2
Make sure all connections are good and tight first.
Old Jul 20, 2006 | 07:47 AM
VanGo's Avatar
VanGo
You can get it tested at a parts store.
I was thinking bad voltage regulator. I can't imagine an alternator wearing too much that quickly. Anything is possible.
Old Jul 20, 2006 | 12:50 PM
Bear River's Avatar
Bear River
Former ******
Best advise any of us can give you is to get it tested at an auto parts store.
Old Jul 20, 2006 | 04:54 PM
96_4wdr's Avatar
96_4wdr
unless belt is less than 5k miles old, replace at same time as alternator.....can save later headaches....
