I realize most of you have heard this one before, but I'm new to this kind of stuff and have had trouble searching through all the forums. I suspect my driver's side window motor is broken. I have the inside panel off and have verified that power is getting to the motor when the rocker switch is toggled up or down.
I guess I'm mechanically-challenged, as I can't seem to figure out how to pull the motor. I found one (1) 7/16" nut that appears to hold the motor to the window panel, but thats where I'm stuck. There appear to be three (or four) pins that align the motor, but I don't know a) how to separate them or b) if I need to.
Can someone give me some guidance on how to get the d___ thing out (and back in)???
