electric window
Old Jul 19, 2006 | 06:53 AM
konan's Avatar
konan
electric window
02 ex power window and radio loses power for a few moments and then after i hear a slight click coming from near fuse panel power returns.i removed window switches and cleaned contacts but has not made any difference.any help as to what i can do next would be appreciated.
Old Jul 19, 2006 | 08:14 AM
Calli's Avatar
Calli
Konan, Try removing window motor and spraying with WD-40 or some other water disperssant. Had to do mine several times. Finally had to replace. Has been garaged last couple of years so no more problem. (Remove panel, vapor barrier and Three bolts that hold motor in place. It will fall out. Very easy to remove and replace. Good luck, Carroll
Old Jul 19, 2006 | 08:51 PM
konan's Avatar
konan
how do i remove door panel?i dont see any screws so do i just pry it off,if i can get the panel off without beating it up it would be nice! thanks again.
Old Jul 19, 2006 | 09:27 PM
Lushman's Avatar
Lushman
Here is a link on how to remove the door panels: https://www.ford-trucks.com/forums/s...ng+door+panels
