ummmm.....well, i speak for myself, but i need more specifics.
i mean older, you can take a 1978 ford and throw a hot rodded 460 in it no problem, it gets more complicated with newer ones because of the computer and emissions stuff.
Thats What I mean any truck say 1986 or older without a computer compared to newer trucks where you can change everything by using bolt on parts and a chip.
I am a fan of the old classics...parts are more affordible and more available. You spend a lot less time scratching your head wondering why the check engine light came on after you modified something. People rely to much on the computer and the art of listening to an engine, or tweeking a carb is dying out.
For example....my wifes car had a bolt siezed up on the fuel rail and I twisted it off when trying to replace a seal on an injector. Since I am stationed in hawaii with very few of my tools I opted to use my free towing to have it taken to a shop. Got it there and the mechanic told me he couldnt fix it because they did not have the ability to extract the bolt. I went and bought the kit and fixed it myself in the Firestone parking lot. That guy ended up saving me a lot of money. Long story short go with the old cars if for no other reason than to support the dying art of turning wrenches, and not using a computer programmer to get the speed.
Its far easier to chip or reprogram a modern one that bolt on a bunch of stuff on an old one. Look at your starting point. The 1970's models that so many here at FTE seem to be in love with came from the factory with low compression, low power and tons of mostly vacuum operated emissions equipment on top of a 1960's basic structure and metallurgy. My 1974 Econoline was a mess. Modern engines have better materials, high compression, roller cams, big valves, some with a three valve OHC heads.
I can agree that newer rigs are easier to get power from, you throw in a chip, a plastic tube here and there, and BAM you got a ton of power. But when it starts hesitating and dies on the side of the road, chances are there will be a towing and repair bill involved that would have bought me several more cars. If one of my older rigs dies on the side of the road, more than likely I can fix or rig something up and continue on my way home. I like the fact that adjusting my fuel mixture will cost me $1 for a screwdriver as opposed to several hundred for a mini-laptop.
The original question was not "how easy can I fix it on the side of the road?". I notice that non-stock equipment generally requires more roadside attention. The question was about ease of getting more power.
Adjusting the mixture on my Econoline (with a simple stock 2 barrel) was tricky when it came time for a smog check. To get it to pass the CO limit reqired it to be within one-eighth turn or less.
Then that depends what part is easier for you, spending money or doing work(if you know how). Here's a simple comparison for building a newer 302/95 F-150 vs. an old 302/74 F-150. Intake for the new truck costs $800 vs old which is $230. Carb $250 vs. TB $300. Exhaust new-$500+(with high flow cats etc.) vs. old-$250-$350(if you want mufflers). It's easier for me to get power from an old truck because I can do the work myself and save even more money(which means more toys). I would have to mortgage my house to even get the parts to pull power from a newer truck which is why I traded my new truck for an old one. If you have money get a newer truck, the power can be had easier. If you are a cheapskate like me and don't mind getting dirty, then I would get an older rig.
Disclaimer-None of the comments made above were meant in a negative or insulting manner. I realized it may have sounded a bit that way after I read it.
I didn't take it in that manner at all.I like the way you made the comparison between parts for each.My wife wants me to get a new truck,like you I'm cheap and like my 86 F250 too much to trade it.It will not be a work truck anymore so I can fix it up the way I want it for less money than a new one.
Thanks everyone for your opinions.
It is much easier to get power from an older engine because you can increase the amount of fuel and air taken in by massive amounts. Pretty much an N/A engine (carb or FI) is limited by the formula 1.33 x CI = max. HP available.
It is a lot easier to put a blower (say a 6-71), NO, headers, and straight pipes on a carb vehicle then an EFI vehicle. Unless you reprogram your own chips.
If you just want to piddle around and imagine each air cleaner change or muffler mod adds 10 horse power, then a newer vehicle might be better.
If you want 500 HP cheap then buying a factory crate 460 or 502 is the way to go.
I already have a 460 in my F250 a good old fashion rebuild is in the works.
Which is "easier" to get power from is dependent upon the knowledge and skills of the particular person to which the question is posed. I can get more power from an "old school" engine much easier than I could from one of today's rolling computers. I'm sure I could screw up a computer controlled vehicle much easier than the older models, too.
By the same token, I would imagine many proponents of late model vehicles would be totally lost if they had to deal with a points/condensor-type igntion system, which about has to be (IMHO) THE SIMPLEST ignition ever made (except for maybe a flywheel magneto system, like on a lawnmower...)
But then, I'm just an old-timer so what do I know?
The question as I read it was which can you get more power from- a modern engine or an older design the easiest. Considering the older engines had so much emmissions on them that strapped them for power and the fact that the older designs were of larger CIs, there is more power to be had from an older design. But that doesn't make it easy. A current 4.6 Triton at 281 CI is making close to one HP per CI which years ago we would have called that a high stressed engine. There isn't a lot of room for any MAJOR gains there. An old 390 that made like 190 HP can be made to get 500 HP with a well thought out rebuild- but is that easy? My personal opinion, the older engines that are making some modded HP sound like a REAL engine whereas the newer ones with their chips and highly tuned exhausts are sounding more ricer everyday. I guess you had to grow up in the 60's when HP was king and everything else was BS. I still think the best sounding engine was a GM 327 but I'm old school.
