Sponsored by: Auxito
help emergency brake stuck
Old Jul 17, 2006 | 01:58 PM
don f's Avatar
don f
how do i get my emergency brake unstuck on my 01 f150 4x4 with disk brakes thanks for any help.
Don
Old Jul 17, 2006 | 02:18 PM
BillyBob69's Avatar
BillyBob69
Could be a number of things....is it in the pedal that won't release? The cable? The calipers?
Old Jul 17, 2006 | 03:19 PM
Hecklerboy's Avatar
Hecklerboy
If your 2001 is like my 2003 then the emergency brake is a set of drum pad that utilize the inside of the rotor. The acuating arm will sometimes get stuck. Pull your wheel try to push the level back by tapping with a hammer. This should release the brake.
My mechanic says Ford has a fix for this problem, so you might want to contact your local dealer.
Old Jul 17, 2006 | 03:20 PM
don f's Avatar
don f
the cabal will not let loose.
amer28
16
Jan 17, 2016 06:54 AM
Eddillard79
Oct 9, 2014 07:15 PM
hivolt5.0
18
Aug 27, 2008 05:09 PM
mbunney
Oct 29, 2003 09:33 PM
2002_SC_FX4_4x4
1997 - 2003 F150
Apr 10, 2002 08:24 PM
