changing gear ratio
Old Jul 17, 2006 | 12:25 PM
plowboy2155's Avatar
plowboy2155
changing gear ratio
I have a 1994 F-150 4x4. It currently has a 3.31 gear ratio. I would like to change this to 3.73. On the interstate it constantly shifts from OD to be able to pull itself.....towing is even worse. I plan on buying a used set of gears from ebay or a local parts yard. I need to know what to look for specifically. I know the rear is an 8.8.....do the truck rear ends use the same gears as the mustangs? Also, will my carrier work with 3.73's? I am almost completely lost when it comes to the front end. I know it is a Dana 44 IFS (Twin Traction Beam). What gears from other D44's will fit in the one I have? Do I need reverse or std. cut? Any help would be greatly appreciated.
