Sponsored by: Kumho
Steering Wheel Oscillation
Old Jul 17, 2006 | 07:41 AM
ktodd's Avatar
ktodd
I recently purchased a 2001 F250 Super Duty Crew Cab with Standard Bed with 97000 miles. When applying the brakes aggressively, I get a fairly large oscillation in the steering wheel that seems to get worse the harder I brake. I had someone tell me that I might have a warped rotor but am not totally convinced that this is my problem. Has anyone else experienced this and if so what was the solution.
Old Jul 17, 2006 | 08:01 AM
mr clutch's Avatar
mr clutch
warped rotor syndrome. Very common in these trucks. The only true fix is to change to a quality set of rotors and pads. You can resurface your current but the problem will return a little quicker next time. Call if you have any questions
Old Jul 18, 2006 | 05:43 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome ktodd, to Ford Truck Enthusiasts!
See you on the boards. ….
Old Jul 18, 2006 | 07:19 AM
davidsca's Avatar
davidsca
It happens. I have an older truck (80 F-150 4x4) and I went through the same thing you are describing. I replaced my front rotors and the problem went away
FWIW,
DS
Old Jul 19, 2006 | 11:23 AM
fordin K's Avatar
fordin K
be sure to torque lug nuts with torwue wrench or equiv. and also make sure all caliper sliding hardware is lubed and slides as suppose too if not the caliper will stick and cause parts to wear abnormally or quicker !
