Dead water temp gauge
The water temp gauge on my motorhome suddenly stopped working on my last excursion with the vehicle. No needle movement at all. At the time of occurrence, I searched this forum, and found several tips about how to troubleshoot which part of the system was faulty. BUT I've tried again recently to find the thread, and cannot seem to locate it :-(
Can anybody provide advice how I should proceed with finding what part of the system (sender, thermostat, gauge, etc) is at fault. I am a novice "mechanic", so please keep the expanation at a basic level.
TIA.
the part should come with some teflon tape already on the threads.
if its a deisel the sensor is located on the very front of the engine. behind the water pump. about 1 o'clock as u look from the front.
good luck.
