Problem?
Old Jul 16, 2006 | 12:38 PM
wb6anp's Avatar
wb6anp
Problem?
I have a new 2006 F250 cc 4x4 Harley /20" tires, it does not seem to have the head snapping accelation that my '05 F250 extended cab 2wd had also don't get as good as fuel milage. Could this be a problem or is it just due to differences in 2wd and 4wd also larger tires. I am unfamilliar with 4wd this is my first.
also is ther any way to change the null area of the throttle pedal I have about 2" of dead pedal on the '06 and only about a 1/2 " on the '05.
Old Jul 16, 2006 | 01:11 PM
Maxium4x4's Avatar
Maxium4x4
The 20" is just rim size not tire diameter.
Old Jul 16, 2006 | 01:50 PM
pamelbert's Avatar
pamelbert
What is your mpg loss. I would guess 2-3. Considering you went from 2wd to 4wd, extended cab to crew cab, 17 or 18 inch to 20's which have 34 inch tires. I would consider that normal. The increase weight of the truck and wheel/ tire combination will cause your loss in mpg.
Old Jul 17, 2006 | 11:23 PM
wb6anp's Avatar
wb6anp
Yes it is about a 3mpg loss, and yes I know 20" was just the rim size I havent measured the tires so I didn't know. P.S. how do you do your tag line.
Mine is a 2006 F-250 Harley Davidson Dark Torreodore red with black flames.
Old Jul 18, 2006 | 08:25 AM
smokefan's Avatar
smokefan
According to the tape measure, the tires that came on my 20's are a little under 33" which is about the same as a 235/85/16 isn't it?
Old Jul 18, 2006 | 08:38 AM
wb6anp's Avatar
wb6anp
not sure maybe somone else knows.
Old Jul 18, 2006 | 05:11 PM
pamelbert's Avatar
pamelbert
235/85/16 are 31.73 inches tall, the tires that come with the factory 20's are 275/65/20 are 34.07 inches tall, if you measure them while they are on the ground they probably will measure less depending on the air pressure of the tire.
