compression test
Old Jul 15, 2006 | 08:59 PM
trandy's Avatar
trandy
Post compression test
Okay guys. I'm a newbe. Farthest I've been in a engine is to repair blown head.
Guess I'l learn the hard way alot but I'm gona learn. Hope you can help. I'm pulling out a 302 in my 92 F-150. Got some noise comming from the main bearing but only under a heavy load. Can't decide on wether to put a new cam an bearings in her or to order a long block reman. i did a compression test and all cylinders are between 175 lbs and 185lbs after 4 rotations. all are comming up to about90 lbs on first 150 on second and the remainder on the last two rotations. also did a preasure test on all and found no measureable leakage.
Old Jul 16, 2006 | 05:28 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
To find out where to ask this question, click on this link
https://www.ford-trucks.com/forums/s...88#post3272088
See you on the boards. ….
Gyrene4Life
Testing.....
Feb 25, 2012 05:33 PM
sea biscuit
New Member Introductions
Sep 6, 2006 05:16 AM
TheWiz427
26
Sep 14, 2003 02:00 PM
