help
Old Jul 15, 2006 | 08:13 PM
jake350nc's Avatar
jake350nc
help
97 F-350 powerstroke that started running ruff and then stalled. Now I can't get it to crank.
Old Jul 15, 2006 | 08:57 PM
believer45's Avatar
believer45
Any modifications to your truck?
When you say it won't crank do you mean it won't turn over at all or it turns over but will not start?
Does it show a check engine light?
If it turns over but does not fire check the fuses in the block on the driver side inner fender under the hood. #22 is the fuse for the fuel heater which also supplies the PCM. If it is blown, there is a plug on the side of the fuel filter housing (under the hood looking thing on top of the engine, you will have to remove it for this). Unplug, replace the #22 fuse and try it again.
Dave / Believer45
Old Jul 16, 2006 | 07:38 AM
jake350nc's Avatar
jake350nc
help
It dose turn over, and no check engine light or water in fuel, also the #22 fuse seams ok, any other advice?
And no, no mods, just standard 7.3 turbo with 160 on it
Old Jul 16, 2006 | 08:16 AM
Cuda_jim's Avatar
Cuda_jim
Is the tachometer moving when the engine is turning over.
No tach movement = bad CPS.
Old Jul 16, 2006 | 08:37 AM
jake350nc's Avatar
jake350nc
Unfortunatley the truck is an XL, so no tach.
Old Jul 16, 2006 | 12:52 PM
1997F-350's Avatar
1997F-350
thats not true.
Old Jul 16, 2006 | 04:06 PM
believer45's Avatar
believer45
Originally Posted by 1997F-350
thats not true.
I thought all diesels came with a tach from the factory as well. I wonder if your dash cluster was replaced at one time?
Dave / Believer45
