04' 2 ~ 3 shift problems
Old Jul 15, 2006 | 12:59 AM
Casey02L's Avatar
Casey02L
04' 4x4 F250 auto; every 2 to 3 shift I get this bad studder/jerking of the transmision shift. Truck has been doing it for a while; just not I have a programmer and notice it more. Once I also had it where it didn't want to shift out of 2nd to 3rd till I let out.
Has anyone had this problem/what was the fix?
Old Jul 15, 2006 | 09:13 AM
Maxium4x4's Avatar
Maxium4x4
You need to have the transmission looked at. Looks like a solenoid is not working right. Your dealer can run a pressure check to make sure.
Old Jul 15, 2006 | 01:32 PM
Casey02L's Avatar
Casey02L
Well; problem is the truck is modded, and lifted. So they are going to blame all that. It's only the 2~3 shift; would it be that solenoid to where I could just buy and replace that myself?
Old Jul 15, 2006 | 02:17 PM
Maxium4x4's Avatar
Maxium4x4
A lazy or stuck solenoid is not because of any modifications. Will be cheaper in the long run to have it diagnosed first. Throwing parts at it is expensive.
<TABLE cellSpacing=0 cellPadding=3 width="70%" border=1><TBODY><TR vAlign=top><TD>175 </TD><TD>7G383 </TD><TD>Solenoid — line pressure (VFS) </TD></TR><TR vAlign=top><TD>176 </TD><TD>7J136 </TD><TD>Solenoid — directly proportional (VFS) (4 required) </TD></TR><TR vAlign=top><TD>177 </TD><TD>7J136 </TD><TD>Solenoid — inversely proportional (VFS) (2 required) </TD></TR></TBODY></TABLE>
Old Jul 15, 2006 | 02:19 PM
Maxium4x4's Avatar
Maxium4x4
You could have a wiring issue in the trans. Remove your tuning, the lift can stay.
Old Jul 15, 2006 | 03:43 PM
Casey02L's Avatar
Casey02L
Hmmm; well. I have a tuner and exhaust on the truck. Also a CCV mod. If I could come up with a likely single part I would rather change it myself than take it to a dealer. Not to mention I hate someone else working on my truck; more usually gets screwed up than fixed.
Old Jul 15, 2006 | 04:36 PM
Maxium4x4's Avatar
Maxium4x4
https://www.ford-trucks.com/forums/s...light=solenoid
Check out this thread, maybe Vloney will chime in.
Old Jul 15, 2006 | 04:58 PM
james gang 1001's Avatar
james gang 1001
I just got back from the dealer for snapring failure and the tech showed me a ford bulletin that said the 2nd- 3rd hard shifting problems were normal and do not attemt to fix these issues
