1978 - 1996 Big Bronco
1992 302 engine mount
Old Jul 15, 2006 | 12:10 AM
sirkt's Avatar
sirkt
I haven't post in this forum in awhile because my Bronco has been benched since I rolled it. I am going to return it to its original beauty but I don't have the money yet. However the neighborhood I live in has a "junk car" ordinance (although some of my neighbors have chevys ) and the car must be able to move under its own power or it is considered "junk". When I rolled it the passenger side motor mount broke (most of the rubber mount material is gone). How hard is in to replace the motor mount and is it something I can do I my driveway?
Thanks everybody,
Tyde
Old Jul 15, 2006 | 02:41 AM
greystreak92's Avatar
greystreak92
It can certainly be done in the driveway. You will need to jack up the engine itself CAREFULLY once you have the old mount unbolted. Once there is enough clearance you can remove the old one and install a new. The process may require loosening the other motor mount but if at all possible avoid completely unbolting the other side so as to avoid having to get both sides re-aligned on the studs/holes. Take care when lifting the engine so as not to damage anything. the fan will not move far before it hits the shroud, the hoses won't stretch forever, the transmission cooler lines (automatics only) run right past the engine on their way to the radiator. Just keep an eye out all the way around.
Old Jul 15, 2006 | 02:45 AM
sirkt's Avatar
sirkt
Greystreak where would I place the jack? On the oil pan? Or is there somewhere else on the block? It was almost dark when I was looking at it so I may have missed something. BTW it has the manual trans, so is there any thing I sould be worried about with it.
Tyde
Old Jul 15, 2006 | 03:06 AM
greystreak92
Watch your shift boot and the like since the tranny is mounted to the back of the engine, the shift lever is gonna move around a bit on you. I am assuming a hydraulic clutch so thats not an issue.
As for the best lift point, you can get a jack under the pan but don't lift with just the saddle on the jack. A heavy piece of wood (chunk of 2x8 works well) or something equally sturdy that is big enough to span the whole of the flat surface across the bottom of the pan should be placed between the saddle on the jack and the pan. This way the weight of the engine is distributed across the entire surface instead of just the point when the saddle touches the pan. If you don't do this you run the risk of seriously damaging the pan and the sump in the bottom of it.
Old Jul 17, 2006 | 10:32 AM
Kemicalburns's Avatar
Kemicalburns
i always jack the motor up from the tranny bellhousing. the oilpan could dent and that would be bad.
RickW2007
WTB - Ford Trucks & other vehicles
Dec 30, 2016 11:54 PM
andrew's64
Jan 26, 2016 11:08 PM
FuzzFace2
19
Dec 14, 2015 12:00 PM
Osiyo59
44
Mar 21, 2015 12:48 PM
Cultsociety
22
Mar 25, 2008 02:13 AM
