Trans and Axle Codes
Old Jul 14, 2006 | 09:46 AM
Phil527's Avatar
Phil527
Hello,
New to this site and new to Ford Trucks. Someone was giving away a 86 F250 with a 460 that needed an assortment of minor mechanical work. I finally got it whipped into solid mechanical shape and was looking to find some info on the tranny/axle setup.
The Door sticker lists Type F257, Trans P, Axle 35, Spring F K
I think it was a factory tow setup, the owner used to do alot of towing out west, it is geared down pretty low- 4 speed manual tranny. I will only be doing some moderate towing occasionally and wanted to see if there were any options to switch to a different ratio rear end or a tranny with an OD to get a little better milage when I get it on the highway.
Thanks for any advice - lots of good info on this site!
Phil
Old Jul 14, 2006 | 02:12 PM
Dungeon_Master's Avatar
Dungeon_Master
Trans code P = Manual 4 speed T-19
Code.......................Man........Size........ GVW…..Gear Ratio, non Limited Slip
Axle code 35.............Ford....................6250....4.1 0
Old Jul 14, 2006 | 11:36 PM
Piffery1's Avatar
Piffery1
Code 33 is essentially the same axle with a 3.54:1 ratio which would probably suit your needs better. You'll need a speedometer gear to match.
