frame width
Old Jul 13, 2006 | 11:02 AM
buckethead5k's Avatar
buckethead5k
Question frame width
were the frame widths different on 4 wheel drive versus a 2 wheel drive?
I bought a second rear axle but the leaf spring mounts are 4 inches wider apart
Old Jul 13, 2006 | 03:57 PM
FordBoypete's Avatar
FordBoypete
No.
But they're different between 72 & 73 as 73 up has wider CA area than all 67-72s, 4X4 or otherwise. Thus a 73 & up rear axle assy will be wider than a 72 or earlier one.
FBp
Old Jul 13, 2006 | 10:00 PM
highboyblue's Avatar
highboyblue
71 frame swaps
Quick ?,
Are the frames on a 71 F-250 2x4 the same as a 71 F-250 4x4? I found a clean 2x I'd love to put the running gear from my ugly 4x on!
Thanks
highboyblue
Last edited by highboyblue; Jul 13, 2006 at 10:20 PM. Reason: typos,more info, needs a separate title
Old Jul 13, 2006 | 11:45 PM
gbrett's Avatar
gbrett
the frames are the same width between 2x and 4x but the front section of the fram is built differently
Old Jul 14, 2006 | 05:55 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome highboyblue to Ford Truck Enthusiasts!
See you on the boards. ….
Old Jul 15, 2006 | 10:55 PM
highboyblue
2x4/4x4 frames
Thanks gbrett for responding and heh Tim!
So are the front of the 71' F-250 frames on 2x4 vs 4x4 so different I'll need ten pounds of welding rod, and $200 worth of steel to switch suspensions? (The 4x body looks worse each time I look at it!)
highboyblue
Old Jul 15, 2006 | 11:08 PM
gbrett's Avatar
gbrett
the frames are very different its doable and has been done but to get it right requires a degree in steering geometry and to get it safe requires a realy good welder you would need to remove the front crossmember from the 2wd frame and fabricate a new crossmember and new spring mounts since the 2wd uses coils and the 4wd uses leafs and then also I think the shock mounts would be different but it would be a simple matter to switch bodies as they would be a direct bolt on
Old Jul 15, 2006 | 11:20 PM
68Mercury250Ranger's Avatar
68Mercury250Ranger
Sandblast and if the 4wd frame is ok, paint it and use it. Keep all your steering column and brake system from the 4wd, they will all bolt into the 2wd cab!
That should be a easy swap. Even for a beginner.
With all the help you get here shouldn't be a problem. COOL TRUCK!
Old Jul 22, 2006 | 10:38 AM
highboyblue
Nice!
Thanks guys. I'll keep you posted. Now to convince the wife about another little project in the back yard, and garage.
Highboyblue
