How do i read the triangle timing marker???
Old Jul 12, 2006 | 09:36 PM
leftystar's Avatar
leftystar
Question How do i read the triangle timing marker???
I have a 1987 f 150 5.0l and my timing marker is different than in the haynes manual it looks like a triangle with one side straight up and down and then where are the dam numbers at?? and for the best performance what is the max it needs to be set i heard 12 is as far as i need to go 10 is stock. if i could get detailed instructions on which side of the marker i need to read from..
Old Jul 13, 2006 | 08:17 AM
subford's Avatar
subford
It should look like this and the point of the pointer is what the timing it is set to.
The numbers are on the damper (crankshaft pulley).
The timing must be checked with a timing light. This device is connected in series with the No. 1 spark plug. The current that fires the spark plug also causes the timing light to flash.
The scale is located on the crankshaft pulley and a pointer is attached to the engine block so that the scale will pass close by. When the engine is running, the timing light is aimed at the mark on the crankshaft pulley and the scale.
hermancm
WTB - Parts & other
Sep 23, 2012 09:40 AM
Gouge Eye
Jul 27, 2012 11:49 AM
DetailerDave
Jan 24, 2012 11:24 AM
willieyp
Aug 17, 2011 10:13 AM
tuffone
General Diesel Discussion
Oct 26, 2008 07:39 PM
