Sponsored by: Real Truck
tailight removal?
Old Jul 12, 2006 | 09:18 PM
Vinford's Avatar
Vinford
tailight removal?
Can someone tell me how many screws in my 02-F-350 superdutys tailights?
Ive removed the 2 inside the tailgate but the light seems to still be attached?
Thanks
Old Jul 12, 2006 | 09:43 PM
dagren99's Avatar
dagren99
Smile Tail lights
That's correct - just two screws but.... There are a pair of plastic "posts" that go into the fender - these snap into the sheetmetal - you just have to pull a little harder than you'd think you would. The lights don't "fall" out once the screws are removed like on older trucks.
I had the same problem the 1st time I took one of my tail lights out too.
DG
Old Jul 12, 2006 | 10:01 PM
Vinford's Avatar
Vinford
Thanks for the advice I gave a good hard pull and they came.
Thought I was going to break it.
Old Jul 12, 2006 | 10:30 PM
ryaneverk2's Avatar
ryaneverk2
I'm never a fan of those compression clips or whatever they're called. Always feels like you're going to break them. They're all over the truck, though. Also seems to me that the more you "use" them (as in removing the taillight housings and reinstalling, etc) that they get worn and loose a bit, and don't hold good and tight like they should.
Old Jul 13, 2006 | 01:30 AM
jake00's Avatar
jake00
I've had to replace alot of tail bulbs as of late..... I was Sure I was going to break the tail light, then ...pop out it came
Old Jul 13, 2006 | 11:05 AM
SpringerPop's Avatar
SpringerPop
Every time I encounter one of those "clips", like the door switch panels and the tail lights, I put a light film of grease on it "for next time".
Pop
