Sponsored by: Auxito
97 ford a/c problems
Old Jul 12, 2006 | 08:26 PM
gmans1283's Avatar
gmans1283
Hey everybody I got a buddy that has a 97 Ford F-150. We recently put freon in it due to the fact the compressor was not kicking on. After adding The compresser stayed running But a/c was still not blowing cold. But the evap. was sweatin and drippin like crazy. What would cause this to happen??? Also when you go drive it if you give it any kind of cas in gear it will jump to burning hot air. I was looking under the dash and discovered that it was elc controls and motors that control the temp. The motor is turning with the switch. but it sounds like a vacume slaming a door shut when you give it gas. Can anybody help me with this. Thank you Greg
Old Jul 13, 2006 | 08:50 AM
deltasoft's Avatar
deltasoft
have you checked your vacum control switch? for example check your temperature switch....you might think its at cold but it might be pointing to hot the stick and handle might be broken...happens...happened to my truck and i discovered it dumbly after recharging system with propper freon.....jeje
Old Jul 13, 2006 | 10:55 AM
projectSHO89's Avatar
projectSHO89
Your blend door is broken.
SEARCH keyword BLEND DOOR
Steve
