ignition swap
Old Jul 12, 2006 | 06:47 PM
GOTH_TRUCKER's Avatar
GOTH_TRUCKER
Exclamation ignition swap
ok im goin from the tfi to the ds2 set up,when i go and hook up the coil the power wire where is at and does it have the resistence in it. and also when i took out the eec and such the oil pressure sending unit came out with all the wires and also a wire that ran behind the tranny wut is the second wire for and wut does it hook to and how do i hook op my oil pressure sending unit. oh,my truck 84 150 xlt ,300 4.9l engine and c6 no emittions and on the way to no eec,thx ya'll
Old Jul 12, 2006 | 10:01 PM
havi's Avatar
havi
I'll have the Roast Duck
I kept my tfi coil and bought a "pigtail" to splice into the green w/yellow and red coil wires in the ds2 harness. works fine. Also look on the driver side by the dist. for the oil pressure unit. Might be a plug there on yours, but mine's an 85 300, and mine screws into the block. One note, my 79 bronco already had the ds2 in it.(see signature) that second wire might be for the water temp, or choke depending on the type of end it has.
Old Jul 12, 2006 | 11:07 PM
GOTH_TRUCKER
thx,so ya i got the harness and such, and the resistence where is it,like in the harness where is the wire i hook it up to,is it in those plugs i unplugged on the driver fender? thx.
