Sponsored by: Auxito
Brakes ????
Old Jul 12, 2006 | 01:34 PM
Oldie53's Avatar
Oldie53
Question Brakes ????
I did a brake job about 2000 miles back and now i get a rubbing and gringing from my left side,and some times righ rear. when I did the brake job i put on new pads and reworked each rotor. Did i get bad pads or what?? Its a 2000 F150
Old Jul 31, 2006 | 05:21 PM
amish77's Avatar
amish77
I'd pull the wheels and check the pads. If they are worn then worry about it. If not then something check the rotors runout. Scratches in the rotor might be the source of the squeak.
Old Jul 31, 2006 | 05:27 PM
ranger88a's Avatar
ranger88a
Usually you get a rust edge that will cause the squeak and grinding noise. Check the brakes first, if ok, take the truck out and hit the brakes hard about 3-4 times. It knocks off the rust edge.
Old Aug 1, 2006 | 08:20 AM
7700Rob's Avatar
7700Rob
Check the caliper sliders and the pad sliders. They shouldn't be rusted (if that's the case) so soon.
2003Navi
Nov 13, 2011 10:37 PM
Dalek Sec
1997 - 2003 F150
May 29, 2011 10:25 PM
l.i._f100
1983 - 2012 Ranger & B-Series
Jan 30, 2008 07:17 PM
Oldie53
1997 - 2003 F150
May 2, 2006 11:07 AM
kylem
Nov 28, 2004 03:26 PM
