my 79 f 250 has set for a little while now i have tight spots when i turn the wheel. nothing is touching or hitting could this be the power steering pump or gear box. this was not happing before it set.
thank you in advance.
Robbin
you checked the fluid right?
you might need to drain whatever fluid is in there
then put some more in, and check the lines
my truck sat for 3 years so i had to check all the lines and empty the fluid in there and change it
no probs since then
