Sponsored by: Real Truck
Found my Cab Leadk!!!!
Old Jul 11, 2006 | 07:27 PM
Studenut65's Avatar
Studenut65
Hello All,
As some of you may know, when the northeast got hammered with rain the other week, my superduty (regular cab 250) go water in it - enough to make the carpet wet. I removed the carpet, washed it, and am ready to replace it. However, first I had to find my leak. I used some silicone to seal any possible windshield leaks - fixed, no leaks. I had a glass repair shop check the rear window - no leaks. Finally found where it was coming from. A welded seam at the rear of the cab is leaking. Also, the rubber seals around the rear cab vents are leaking. Now, in order to seal this, I need to remove my bed to get to the back of the cab. How hard of a job is this? Any recommendations or hints? Thanks,
Nate
Old Jul 11, 2006 | 09:15 PM
99f350sd's Avatar
99f350sd
Just pull out the bed bolts and maybe the filler pipe and see if you can slide the bed back 4 or 5 inches. I had leaking vents also..
Dick
Old Jul 12, 2006 | 05:35 AM
rwilimo's Avatar
rwilimo
Could they sealed from the inside? Might be easier
