hi.
my temp gauge doesn't work.
i changed the gauge but it doesn't help.
i think that it could be a temp sender but i can't find it?
I found one with two wires, but this is probably sender to computer.
Where is located the temp sender to dashboard?
Its drivers side front on the lower intake. There is a single wire attached to a stud sticking out the top, and it's very small.. about the size if a penny in diameter.
