Sponsored by: Auxito
trailer lights dont work
Old Jul 10, 2006 | 07:53 PM
shanesF150's Avatar
shanesF150
Ok my running lights have naver worked sence i can think.
The brake lights and turning signals worked untell the + power on
the 6 or 7 hole thing grounded out..
the + wire got grounded out and now the brake and turning dont work
and i dont know if my trailer brakes work yet because I havent tryed yet.
Is thare a set of fuses I sould look at or what ???
Thanks for your help and hopefully its nothing to bad.
Old Jul 11, 2006 | 07:53 AM
grafekie's Avatar
grafekie
I'm having trouble figuring out what exactly you are saying. There are fuses for each individual wire, yes.
Old Jul 11, 2006 | 09:43 AM
qdude79's Avatar
qdude79
Check for continuity through the connector behind the driver's side rear fender well. I had to run jumpers over mine, as the connector has gone bad on some parts.
Qdude
Old Jul 11, 2006 | 01:06 PM
Jeffman's Avatar
Jeffman
There's a 20Amp mini-blade fuse that poped on me that powered the marker lights etc.. when the headlights were turned on. Its in the fuse block under the hood. The row of fuses closest to the fender next to the horn fuse. I swapped it out with the horn fuse, also 20A but killed the cruise control in the steering wheel. Either way it sounds like you have something shorting on the trailer or harness.
Old Jul 11, 2006 | 02:10 PM
shanesF150's Avatar
shanesF150
i will check under the hood for the fuses today and get back to you on how it works out.
Ellie&Moose
1983 - 2012 Ranger & B-Series
Sep 21, 2013 08:18 AM
jjlrrw
All Things Towing
Dec 19, 2011 08:54 AM
orangecrate
Jul 10, 2011 10:27 AM
Jbailey52
Electrical Systems/Wiring
17
Mar 12, 2008 05:37 PM
tvulcan
Feb 12, 2005 07:19 AM
