Sponsored by: Auxito
K&N FILTER PROBLEMS...
Old Jul 10, 2006 | 05:59 PM
loaferoatan's Avatar
loaferoatan
All:
I just installed a K&N 77 series performance filter kit on my 1997 F150 4.6L 4X4..followed the instructions to the 'T'...everything's tight and fits snug...I test drove it and loved the sound..UNTILL this hum started....HMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMM.. .kinda loud,,it comes and goes around idle...HELP!!
thanks
Loaf
Old Jul 10, 2006 | 09:23 PM
Trevor1's Avatar
Trevor1
Smile No Problem.
Most k&n intakes are louder than the stock airbox, I have a 2001 5.4 with the k&N air intake and it is louder than stock.
Old Jul 10, 2006 | 10:13 PM
loaferoatan
This ain't a GRRRRRRRRRRRRRRR when driving ( which i love the sound of ). It's a loud hum like a trumpet when the car is idle or has just been started. Could it be a vacuum problem, because if you put your hand near the filter it feels like it's sucking. If it's this how do i fix it? thx
Old Jul 11, 2006 | 07:24 AM
triton54's Avatar
triton54
I had the same issue with my old expedition 5.4. After about a week of pulling my hair out I found the problem. The elbow on my vaccuum line for what I believe was my pcv valve(runs from the valve cover to the rear of the manifold) the elbow on it which is supposed to be a hard plasic was replaced by a section of hose. It got hot, and weak, then collapsed so to speak and was pinching together causing a trumpet sound like you said. If you hit the throttle does it stop? When you hit the throttle it by passes that valve thats how i narrowed mine down. good luck on your annoying adventure and keep us updated.
Old Jul 11, 2006 | 11:18 AM
loaferoatan
i'll check it out..i did suspect it was that..it is an odd angle and in the middle it is pinched a bit...so replace it with a longer hose?
Old Jul 11, 2006 | 05:14 PM
triton54's Avatar
triton54
you can get the whole assembly from a dealer $30 they should stock it
