I would stick to a narrow tire. I've never heard of a 31x8R15, so they must not be too common. Do you need something 31" tall? I like running a 235/75-15 because they are common and cheap, but they're only about 29" tall.
Yeah, i'm having a serious issue trying to find tires that'll fit the truck. I wanted somthing comperable to 31" tires. What are everyone else running?
What gear ratio do you have, and how fast do you normally travel(70?55?).
I ran 235/75R15s on my 77 F-100 302 C4 and I was getting 16 mpg with 3.50 gears
I swaped on some 31x10.50R15s, and it went down to a consistant 14 mpg, so with gas prices, I'm back down to the 235/75R15s.
I'm like you, I think the 31s look great, and personally I hate the look of the small tires I'm running on stock wheels and hub caps, but for 2 extra miles per gallon, I'll keep them on.
So what would 245/75R 15 tires do, improve economy a little or hurt it a little compared to 235's?
This is on a '75 F-250 Supercab, 390, 3.54 rear.
Ray Mac
If you drive on the hwy alot, then yes your RPMs will be lower causing better MPG, but if you strickly drive in town(like I do), you have better mileage with 235s(just for the reason that you will have the most take off power with that combination, and that's what you need in city driveing).
A taller/larger tire will have more rotational mass to get moving and keep moving. It takes more work to do this, and according to physics, work isn't free. More work = more gas. Taller than stock tires on a vehicle will get worse mpg on the highway and so will wider than stock tires.
And then the engine has to work harder, thus lowering mpg. The taller tire is a larger "lever" than needs moved. It takes more force to move this larger lever.
I'm telling you what doesn't work to increase mpg, and it's a taller tire. The best tire size to me on a dialy driver would be the one that gets the best mpg.
I wonder why the econo-cars that get best mpg (50-60 mpg) have such short tires? It seems like if a taller tire = better mpg, they would all run some tall, thin 44's?
Like 460 said, a taller tire is harder to start rolling causing bad mileage, but like you said it will lower RPMs on the highway, but for instance when I had 3.50 gears and 36s, I would guzzle gas getting up to 70 mph, but once I got there, my rpms would be like 1,500(which wouldn't off set all the gas used to get up to 70 mph), so taller tires do = less mileage also.
