67-72 Radiator core support bushings
Old 01-24-2000, 07:55 AM
jowilker's Avatar
jowilker
jowilker is offline
Old 01-27-2000, 01:17 PM
fordhelp's Avatar
fordhelp
fordhelp is offline
Does anyone know where to buy new rubber radiator core support to frame bushings for a 1972 F250?
Old 01-27-2000, 04:08 PM
Trail_Rider's Avatar
Trail_Rider
Trail_Rider is offline
Unless I am missing them also I didn't know there were any. My radiator on my '72 bolts in without any kind of bushings. I've been running mine this way since '91 when I bought it.
Trail Rider
Old 01-27-2000, 04:20 PM
jowilker's Avatar
jowilker
jowilker is offline
fh, call Carolina Classics 800-598-4211, they will have the proper parts that you need.
John
66 F100s
In the still cool hours of the night, you can hear chevys rusting away.
Old 01-27-2000, 09:39 PM
Like M. Fords's Avatar
Like M. Fords
Like M. Fords is offline
They are commonly called body mount or cab mount bushings and should come in a kit with bushings and hardware for the entire cab. It is best to replace the bushings at all 6 locations so that everything will fit straight and level again.
While you are at it, pay extra close attention to the left and right center mounts of the cab (under the front of the floor board) for any rust and/or cracking. I am not sure if this is a common problem in the 67-72's, but our '70 F350 truck at work was so bad here that it created a 1 inch gap between the bottom front corner of the door and the fender. We were actually relieved to find this problem; knowing now that it was not a bent frame. After some 1/8" plate and a little welding, she is sitting as straight and as proud as ever.
Old 01-28-2000, 12:24 PM
wnelson's Avatar
wnelson
wnelson is offline
You did miss something, the radiator bolts to the radiator core support (the frame that holds your radiator) which mounts to the frame with rubber bushings that deteriorate after many years.
Old 01-28-2000, 10:20 PM
Trail_Rider
Wnelson,
Thanks for the clarification. The only thing I could think of was the rubber bushings that support the bottom of the radiator on a car. As I read thru the above posts I realized what he was asking about.
Trail Rider
bradphx
67
01-10-2024 06:12 PM
Aerostar
01-14-2015 03:16 AM
miko6810
Modular V10 (6.8l)
06-04-2014 06:14 AM
Oklahoma Chapter
04-11-2003 10:33 PM
walterdanek
16
02-16-2001 07:56 PM
Quick Reply: 67-72 Radiator core support bushings
