Window Noise
Old Jul 10, 2006 | 08:44 AM
slychicken37's Avatar
slychicken37
Window Noise
This is a very simple problem, but I want to make sure I get the correct part the first time I order it.
On both the driver & passenger windows I get very bad wind noise, and this is what I want to fix.
The noise is coming from the felt channel that the window slides into when the window is in full up position. There is also wind noise coming from the felt channel that is in the vertical member between the main window and the little vent window.
Does anyone know exactly what these window parts are called. I have looked at blue oval truck parts and they have a few things that look like they might work, but they are confusing to me. I think the product I need the get is the "Glass Run, Part # DC-0052" from Blue Oval Truck parts.
Please let me know if anybody can name the exact part, or knows what I need to get.
Thanks
Old Jul 10, 2006 | 01:23 PM
Rosie's Avatar
Rosie
These parts are called window felts. Replacing them will make your windows not whistle. I believe Blue Oval sells a whole kit thats a lot cheaper than buying individual parts. The kit will keep you from missing parts your might need. Hope this helps
Old Jul 10, 2006 | 01:41 PM
Piffery1's Avatar
Piffery1
I got my "window channel run kit" from J. C. Whitney several years ago, least expensive I could find at the time. Kind of a PITA to install but well worth the effort. I replaced window belt molding at same time. Also check Raybuck Auto Body Parts and LMC Truck. Maybe eBay Motors auction.
