How to replace expansion valve...
I am fixing the AC in my 1985 F-150. I have got the evaporator out and I am going to flush it and clean it. I would also like to change the expansion valve while I have everything apart.
How do I get the old valve out? Am I correct that the expansion valve looks like a grey peice of plastic that sits inside one of the evaporator's tubes? How do I change it? Do I just yank it out?
Also, when I opened the plastic housing to get the evaporator out, I noticed that it was sealed with what I can only describe as "black goo." It was very sticky and very gooey. What is this stuff? I might want to add some more to seal it when I put it back together? What can I use? RTV silacone?
Thanks,
Sal
Thanks,
Sal
You shouldn't need to remove the evaporator unless it's leaking. Since you do have it out, look for oily dirt on the fins as this would indicate a leak. Clean it good (the outside)with a purple Power type cleaner.
The sealer goo is called mastick. You could use RTV but I would recommend Strip Caulk, available at most real parts stores or body shop supply stores.
Hope this helps.
