Front hub issues.
Old Jul 9, 2006 | 05:20 PM
hutch1973's Avatar
hutch1973
Front hub issues.
This question is about my latest purchase, an 89 F150 xl 4x4. It's a 5.0. auto.
Had some noises up front and went to pull the front end apart to inspect. The hubs seemed to fit loose (Warn lower end model) even though the allen screws seemed tight enough. Took them off and had huge issues, allen screws stripping out, and finally just said Removed by Admin: inappropriate comment for a family site l it and took a drill/grinder to it, and bought new premium Warn hubs.
The grinding work I did was just on the outter assembly, didn't touch anything outside of that. The new hubs don't fit much differently then the old ones, and they don't appear to be engaging. I lifted a tire, post assembly, locked and unlocked the hub, and I couldn't get the drivetrain to move in either position when I spun the tire. (per manu. directions).
I haven't used the 4x4 in the truck yet, so I don't know that they were working with the old hubs. I disassembled/put it all back together the exact same way (not anything to it).
Now what? I'm wondering if this truck had the auto hubs, they changed them to manual, but didn't get all the right parts? I'm working on finding an exploded view of the hub to make sure everything is in there...
Old Jul 10, 2006 | 07:38 AM
cradar69's Avatar
cradar69
What you need to verify is that in the hub is a conversion kit. All it is is a set of lock nuts and a washer with holes in it. This is what gives you your bearing tension. The nuts need a special spanner nut wrench to tighten or loosen them. The stock Ford nuts do not require this tool. To upgrade from Ford's not so great auto-hubs you need both the manual lockers and conversion kit. The conversion kit can be bought at any parts store or they can order it. I have upgraded 5 trucks between dad and I. Let me know what you find I have some other suggestions but this seems to be the problem you are having. If this is not your problem give me a detailed description of the order of parts you have put back in the hub and what order.
